Audio delay/lag on new slide
After uploading my SCORM onto the LMS platform, I’m noticing a 1-2 second delay in the audio when beginning a new slide. This wasn’t an issue in the offline HTML5 Preview, so maybe it’s a server issue. Has anyone else experienced this and is there a workaround?
If you see audio delay, it could be because your server/LMS is bad or your network is slow.
In case the audio is cut off in the first seconds, kindly take a look at my answer in this thread: Audio delay on xAPI - #2 by PhuongThuy_Le to get the workaround.
BR,
