Apply Word Wrap Textbox?
Can I apply word wrap to a textbox/fill in text/fill in blank questions?
ActivePresenter Version: Required. 8
OS: Required. Windows 10
Could you please explain why you need to apply word wrap to a textbox/ fill in text entry/ fill in blank question? You can easily resize the text box to fit the length of characters inside it.
With the current behaviour typed text can run off the screen.
Has this been addressed? I’m having the same issue with needing word wrap in a text entry object. I have an activity that has a text entry that is populated dynamically with a list that can be edited by user but the list runs off the screen. Resizing the textbox to fit character length is not an option for me, this is happening in runtime
Could you please try using the Essay question in this case to see if it helps? If not, kindly share a screenshot of the problem or a sample project with us so we can take a look and assist you better. If the project is large, you can email us at support@atomisytems.com.
