Currently, I have to change every cursor path’s cursor on every slide manually.
It is redundant, as for our project we have a specific cursor image that is used for ALL slides every time.
It would save a lot of time to have a feature that would apply the selected cursor image to all of the slides in the presentation.
Thank you, that actually helps in some cases (even though i have to re-do the timing etc… so i’ll have to see if it saves time or not )
I wish there was an “Apply to All” option for this, but this helps for now…
Thanks a lot!
