AP 10.6 - Play Audio On Click not working for Drag-n-Drop questions
Problem: When creating a Drag-n-Drop question, if a Drag Source is selected and an Action added On Click - Play Audio, the audio file chosen will no longer play when the Drag Source is clicked. It worked in version 10.5, so is this a bug or has something changed?
ActivePresenter version: 10.6.1
OS: Windows 11
Hi James,
Thank you for reporting this issue, and sorry for the inconvenience. Our team is working on a fix and we’ll let you know as soon as it’s ready.
Thanh
Hi James,
We would like to let you know that the issue you reported has been fixed in ActivePresenter 10.6.2.
Please update to the latest version and give it a try.
Thanks again for reporting it and helping us make ActivePresenter better.
Thanh
