Animated Text Directly on AP
I would like to know about the possibility to animate text directly in ActivePresenter similar to a typewriter, or letters/words appearing with an effect or something like that, not like a transition.
Thanks.
I think it is a useful feature. We will try to support it in the future.
Hello,
has there been any progress in this regard? I would like to simulate test type into a web page box without using the screen recording functionality in order to keep the file running smoothly on limited connections.
Is there a way to simulate type text ? If it is very short I use a set of print screens but for longer texts this does make sense… the text box interaction is animated but only in Demo mode.
Any other solutions?
Thanks a lot,
Michael
Michael
Hi Michael,
The Text Animation feature will be supported in the release of AP 8, which is scheduled for the next September.
Stay tuned for our upcoming release.
Thanks,
