Is it possible to create a flash of light or light explosion with Saola Animate?
Thanks,
John
Thanks,
John
Hi John,
It’s been a while! We hope you’re well.
Could you provide a more detailed description of your question so we can understand it better? A video or any resources illustrating your idea is appreciated.
Looking forward to your response.
Hi Thuy,
Thank you for your quick reply, it is greatly appreciated.
This example is what I had in mind.
Thanks again
John
Thanks for attaching the video, @John_LaFountaine.
Basically, Saola Animate can create the light explosion but at a certain extent.
For example, insert a light explosion image, then use Saola Animate effects to show or hide it.
If you want to loop effects, you can add a trigger at the end of timeline. Please see detail in the example below:
Hope it helps.
Perfect example, deepest thanks.
