Adding tables to a slide
Does anybody know how to add a table? I’ve been through all the menus and can’t seem to find tables anywhere. Thank you in advance.
Hi Roger,
The current version of ActivePresenter doesn’t support table. However, you can create a table in PowerPoint then copy/paste it into ActivePresenter. We will try to support this feature in the near future.
Thank you. I did a workaround for now by creating several side-by-side box shapes all with the same TOP measurement to align my columns at the correct horizontal locations. I didn’t need horizontal lines in my case so this worked well.
