Hi.
Is it possible to import more than one srt file for subtitles?
I saw that it’s possible to add languages, but it’s necessary to change one line at a time and it’s very annoying.
The best solution would be to import many srt files and exporting hard subtitles depending on hided ad showed subtitles.
Are you planning to improve this section?
Thank you
Stefano
It is not possible to import more than one .srt file for subtitles in the current version of ActivePresenter.
While this feature is on our TODO list, its implementation may require additional time.
Hope that it will be available in future major updates.
Best regards,
Bộ phận hỗ trợ đã nhận được email của bạn.
Chúng tôi sẽ liên hệ và giải đáp vấn đề của bạn theo email bạn đã liên hệ.
Trân trọng,
