Adding Images to a text box
Is it possible in a scrollbar enabled text box (see topic: Text box scrollbars) to also add images that are placed in the text, in the text box, as illustrations for information presented?
Example:
lines of text, lines of text, lines of text
etc.
Is there a way to do this with JavaScript or HTML5 or CSS tags?
Thank you for your help.
Best Wishes,
I’m afraid that it’s not possible. You must use texts and images as separated objects.
Hi Toan,
Thank you for writing back.
OK. I can redesign the lesson so that images that illustrate concepts discussed in the text are placed on the side of the slide or can be viewed by a user interaction (for example, a button that shows/hides an image). There are many other options available. :smiley:
Best Wishes
