pixelink
(Frank Hilton)
1
How do I add a “hand” cursor to a button (that is an image) so that when I hover over button, it changes cursor to a hand instead of pointer?
Having a tall canvas that go beyond the view-port with a vert scrollbar.
When a button is clicked, how can I scroll the page back to the top.
Saola Animate version:
2.6
OS:
Win10
ToanLS
(Toan Le)
2
Hi Frank,
You can try the “grab” cursor:
If it’s not suitable, you can use your own custom cursor as guided in this thread:
pixelink
(Frank Hilton)
3
Cool, I was hoping for some thing like that. Wouldn’t of thought of looking under the text property though seeing my button is an image.
Thanks
ToanLS
(Toan Le)
4
It’s in General section. I’ve just updated the screenshot.
