afei
(阿非 碼農)
November 4, 2021, 12:49pm
1
Without the color keyframe setting
for Gradient Fill.Position; Color; ,
I don’t know how to create the sunset color changing as below:
from
to
Please add keyframe settings (diamond buttons)
to Properties.Styles.Fill.Gradient Fill.Position
and Properties.Styles.Fill.Gradient Fill.Color .
Afei
Quynh
November 5, 2021, 1:59am
2
Hi Afei,
We will consider implementing this feature if having more requests from users.
Quynh
fadi
May 5, 2023, 8:49pm
3
I just added a shape with gradient fill and just discovered that I can’t add it to a keyframe. Is there a workaround this issue?
I created two shapes with two different gradient fills, how do I show one but hide the other one at the same keyframe?
Hang
(Hang Nguyen)
May 8, 2023, 3:25am
4
Hi Fadi,
For the first question, adding opacity keyframes to a gradient shape can help create a sunset-alike effect.
For the second question, to show one shape and hide the other one at the same time, you can use a timeline trigger (Use Timeline Triggers in Saola Animate 3 - Atomi Systems, Inc. ):
Please refer to this sample for more information:
gradient effect.saolapack (2.0 KB)
Hope this helps.
