Problem: I’m trying to record system audio while making a screencast. The system audio line is in timeline, and it will play youtube, but doesn’t not capture my mouse clicks. Same as when I manually add in a cursor path (no mouse click sound).
It seems that your cursor effects are not recorded because of the default settings. But ActivePresenter allows you to customize the settings before recording or even after recording.
Before recording, please go to the Recording Settings for Video/ Record Settings for Software Simulation dialog > Cursor tab > Cursor Effects section > select On.
After recording, navigate to the video Properties pane > Media tab > Cursor Effects section > adjust the settings as you want.
