ActivePresenter audio editing problems
Problem: Audio lags, delays, then “not responding” crashing every time I try to edit a screen recording thru ActivePresenter
I tried chopping it up and using shorter pieces of the recording per file, and it doesn’t matter if the video is 90 minutes long or only 9 minutes long. It delays audio every time. The audio playback doesn’t start until the video has been playing for a second or two, then the audio doesn’t line up with the video nor the waveforms so I can’t see where to cut.
If I export the file, the resulting vid and audio is perfectly synced. It’s just during editing
ActivePresenter version: 10
OS: Windows 11
Hi Suzanne,
Thank you for the information.
Could you please send us:
  • Your PC specifications (CPU, RAM, GPU, and OS version)
  • The ActivePresenter log files
  • The project file where the issue occurs
These will help us investigate the audio lag and crashing issue during editing.
You can send the files to support@atomisystems.com, and we’ll take a closer look at the issue.
Best regards,
Same thing happening my side, audio plays after some seconds.
Hi @chiragjoshi,
Could you please provide your PC specifications, ActivePresenter log files, and the project file where the issue occurs?
You can send the files to support@atomisystems.com so we can investigate further.
Also, please update to ActivePresenter 10.6.0 and let us know if the issue still occurs.
Best regards,
Giang
