hi, Ive AP 7.5.9 licensed version bought 2019-12-7.
Ive free upgrade until 2020-12-7
Seems the latest version is AP 8, however Im unable to upgrade to v8.
Kindly suggest.
Kindly suggest.
You can check if your product key can be used with the latest version or need upgrading at:
https://atomisystems.com/upgrade/
Just enter your product key and click Check Upgrade.
If you believe there is something wrong, please contact our support@atomisystems.com with your product key or order reference so that we can help.
