Hello, I created a quiz with 10 questions. I want to see the total time spent in this quiz. Is there a way?
You can use the apElapsedTime variable in this case. This variable returns the total amount of time that has passed since the user first started viewing the HTML5.
This is what I was looking for thank you
Good morning to you!
Sorry to take advantage of this discussion, but my problem is inherent…
is it possible to lock the “apElapsedTime” time counter in the final report?
Because the time keeps going on…
Thank you very much!
HI Betty,
To lock the apElapsedTime time counter in the report slide, you can add the End Presentation action to the Report Slide’s On Load event like this:
Best regards,
Hang
Funziona! Grazie infinite e buona giornata!
