Hi Atomi
I see that I can swap and replace images. Is there a way to do it with .mov files?
Thanks
After importing a .mov video into ActivePresenter, you can replace it with another one by navigating to the Properties pane > Media tab > Video section > Select a video from your current project or from your computer folder.
Hope it helps.
Best regards,
Thanks so much.
Is there a way I can control which frame a .gif or movie is on?
Example, make it stop on frame 3 of the gif after clicking it?
Thanks Thuy!
R
