100 grade not reached
Problem: In this project one slide is requering grading (the first one) but there is not ID report element in the slide, and at the end of presentation the grade is not reached to 100 (using one ID report element at the end).
I solved that erasing the slide and making it again, but I have the question about what could be happening and how to solve it (I hope) without having to remake the slide.
BienestarFinanciero_Modulo3_Prueba.approj (1.9 MB)
ActivePresenter version: 9.1.1
OS: Windows 10
Note: There is a hangman activity and a Javascript code to download files in the project, if you need to use it to extend functions of ActivePresenter or as an example template I have no problem.
The problem is due to the Continuar4 button, which has the Report ID checked in slide 1. This button is covered by the Continuar1 button in front of it.
To resolve the issue, you can delete that button if don’t need it or uncheck its Report ID option.
Best regards,
Now I can understand, I didn´t see that double Next button, thank you so much.
Thank you for your response.
We advise using shape or button objects for creating buttons in ActivePresenter, rather than using mouse clicks. This approach eliminates the need to uncheck the Report ID option. Additionally, using a mouse click may require extra time to determine if it’s a double click or not.
Best regards,
