Hello,
we are having some problems with the position of the images between ActivePresenter and the browser. ¿How can we fix this?
BROWSER:
ACTIVEPRESENTER
You can download our sample project here.
TIA.
Regards.
Hello,
BROWSER:
ACTIVEPRESENTER
TIA.
Regards.
We’ll check your project and get back to you soon, Monica.
Hi Monica,
We have checked and seen that there is a small difference when calculating paragraph spacing between ActivePresenter and browsers so the issue. This spacing also varies between browsers and fonts used.
You can try to use another font (Arial, for example) to reduce the effect of the issue and select the Embed Fonts option when exporting to HTML5.
Unfortunately, there is no reliable way to fix this issue completely.
