Does anyone know what this means after updating Active Presenter:
It is when I try to add Text to Speech, Any help appreciated.
Bob
Bob
Hi Bob,
Could you let me know which provider you are using to get voices?
If you are using Microsoft Azure, a user has reported the similar case recently.
You will need to edit the Speech Endpoint.
If that is not the case and you are using another provider, kindly provide us with more information about the region and the steps where you got errors.
Then, please send us the log file following the instruction here: https://www.youtube.com/watch?v=qdt7Z5h5bVc
BR,
Quynh Anh
Yes, it was Azure, and it did work.
Thanks very much. Bob
Glad to know it helps, Bob.
Please feel free to ask another question should you encounter any other issue.
Kind regards,
Quynh Anh
