After video recording the webcam video cannot be loaded:
Any idea to solve this
Hi Born,
You can find the webcam video in the ActivePresenter Cached folder (C:\Users\Username\Documents\ActivePresenter.ActivePresenterCachedProjects). Then, you can create a new project and insert the webcam video into it.
In case you cannot find it, I am afraid that there is no way to recover.
Besides, please kindly share the log file so we can check? To view the log:
Yen
But my problem is: I get this error message every time.
I tried to remove the whole ActivePresenter directory. When its is recreated on the new application start a .ActivePresenterCachedProjects folder is not even created when I do a video recording. All the other files are in temp, see image:
I think, the webcam file is either written to a different place or not written at all.
How can I set the tempdir directory to a different path?
Thanks for help,
Achim
Hi Born,
Please kindly share the log file so we can check.
To view the log:
Yen
Here are the last 2 log entires:
2021-11-22 07:48:45: ActivePresenter 8.5.4 - 64-bit build. (Release Build: 2021.11.18) started
OS: macOS Sierra Version 10.12.6 (Build 16G1710)
CPU Count: 8
Hostname: 192. Memory: 15,603 MB. Available: 6,269 MB. Memory Load: 59%
Disk Space: 953,284 MB (Free: 14,412 MB)
Project Location: /Users/born/Documents/ActivePresenter/
2021-11-22 07:48:45: TempDir: /Users/born/Library/Application Support/ActivePresenter/temp
2021-11-22 07:48:50: flt sample format is not supported, s16 will be used
2021-11-22 07:48:50: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-11-22 07:48:50: Preparing to record audio from: Background Music. Channel: 2. Sample rate: 48000. Sample Format: 8
2021-11-22 07:48:50: Failed to load icon: microphone_on_128_d.png
2021-11-22 07:48:50: Failed to load icon: capture_fullscreen_selected_128_d.png
2021-11-22 07:48:50: Failed to load icon: capture_customsize_128_d.png
2021-11-22 07:48:50: Failed to load icon: capture_fullscreen_128_d.png
2021-11-22 07:48:50: Failed to load icon: capture_customsize_selected_128_d.png
2021-11-22 07:48:50: Failed to load icon: microphone_off_128_d.png
2021-11-22 07:48:50: RLWebcamImpl: Finding formats for pixel format 17
2021-11-22 07:48:50: RLWebcamImpl: Finding formats for resolution 640x480
2021-11-22 07:48:50: RLWebcamImpl: Finding formats for frame rate 30000030/1000000
2021-11-22 07:52:41: ActivePresenter 8.5.4 - 64-bit build. (Release Build: 2021.11.18) started
CPU Count: 8
Hostname: 192. Memory: 15,616 MB. Available: 4,928 MB. Memory Load: 68%
Disk Space: 953,284 MB (Free: 14,296 MB)
2021-11-22 07:52:41: TempDir: /Users/born/Library/Application Support/ActivePresenter/temp
2021-11-22 07:52:46: flt sample format is not supported, s16 will be used
2021-11-22 07:52:46: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-11-22 07:52:46: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 48000. Sample Format: 8
2021-11-22 07:52:46: Failed to load icon: microphone_on_128_d.png
2021-11-22 07:52:46: Failed to load icon: capture_fullscreen_selected_128_d.png
2021-11-22 07:52:46: Failed to load icon: capture_customsize_128_d.png
2021-11-22 07:52:46: Failed to load icon: capture_fullscreen_128_d.png
2021-11-22 07:52:46: Failed to load icon: capture_customsize_selected_128_d.png
2021-11-22 07:52:46: Failed to load icon: microphone_off_128_d.png
2021-11-22 07:52:46: RLWebcamImpl: Finding formats for pixel format 17
2021-11-22 07:52:46: RLWebcamImpl: Finding formats for resolution 640x480
2021-11-22 07:52:46: RLWebcamImpl: Finding formats for frame rate 30000030/1000000
2021-11-22 07:53:25: Failed to load icon: capture_fullscreen_selected_128_d.png
2021-11-22 07:53:25: Failed to load icon: capture_customsize_128_d.png
2021-11-22 07:53:26: Failed to load icon: capture_fullscreen_128_d.png
2021-11-22 07:53:26: Failed to load icon: capture_customsize_selected_128_d.png
2021-11-22 07:53:40: Start capturing. Mode: Full motion. Method: 0. Capture Size: (1680, 1050)
2021-11-22 07:53:40: Video Codec: h264_videotoolbox. Expecting FPS: 30,00
2021-11-22 07:53:40: RLWebcamImpl: Finding formats for pixel format 17
2021-11-22 07:53:40: RLWebcamImpl: Finding formats for resolution 640x480
2021-11-22 07:53:40: RLWebcamImpl: Finding formats for frame rate 30000030/1000000
2021-11-22 07:53:40: Video will be recorded to: /Users/born/Documents/ActivePresenter/.ActivePresenterCachedProjects/Ohne Titel_tempdir/webcam_20211122_07-53-40.mkv
2021-11-22 07:53:40: RLMedia: Color range not set for yuv420p. Using MPEG range.
2021-11-22 07:53:40: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-11-22 07:53:40: Video will be recorded to: /Users/born/Documents/ActivePresenter/.ActivePresenterCachedProjects/Ohne Titel_tempdir/video_20211122_07-53-40.mkv
2021-11-22 07:53:41: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2021-11-22 07:53:41: flt sample format is not supported, s16 will be used
2021-11-22 07:53:41: Audio will be recorded to: /Users/born/Documents/ActivePresenter/.ActivePresenterCachedProjects/Ohne Titel_tempdir/audio_20211122_07-53-41.wav
2021-11-22 07:53:41: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 48000. Sample Format: 8
2021-11-22 07:53:41: Audio 2 will be recorded to: /Users/born/Documents/ActivePresenter/.ActivePresenterCachedProjects/Ohne Titel_tempdir/audio_20211122_07-53-41_1.wav
2021-11-22 07:53:41: Preparing to record audio from: Background Music. Channel: 2. Sample rate: 48000. Sample Format: 8
2021-11-22 07:53:44: Waiting to start in 2646
2021-11-22 07:53:44: RLMedia:
2021-11-22 07:53:45: RLMedia:
2021-11-22 07:53:46: RLMedia:
2021-11-22 07:53:47: RLMedia:
2021-11-22 07:53:48: RLMedia:
2021-11-22 07:53:49: RLMedia:
2021-11-22 07:53:50: RLMedia:
2021-11-22 07:53:51: RLMedia:
2021-11-22 07:53:52: RLMedia:
2021-11-22 07:53:55: PrepareRibbonBar: 1667ms
2021-11-22 07:53:52: Stop video recording. Frames recorded: 131. Dropped: 0. Duration: 7954. Average FPS: 16,34
2021-11-22 07:53:53: Stop webcam recording. Frames recorded: 0. Dropped: 0. Duration: 0. Average FPS: 0,00
2021-11-22 07:53:53: Recorded video data size: 448 KB
2021-11-22 07:53:53: AddVideo2Slide: Time spend: 100 ms
2021-11-22 07:53:53: RLMedia: Duplicate element
2021-11-22 07:53:53: RLMedia: Read error at pos. 187 (0xbb)
2021-11-22 07:53:53: Warnung: Aufgenommenes Webcam-Video konnte nicht geöffnen werden: /Users/born/Documents/ActivePresenter/.ActivePresenterCachedProjects/Ohne Titel_tempdir/webcam_20211122_07-53-40.mkv
2021-11-22 07:53:53: ProcessRecordedAudio: duration (ms) 8292,125000
2021-11-22 07:53:53: ProcessRecordedAudio: duration (ms) 8427,896000
2021-11-22 07:54:08: RLMedia: No streams to mux were specified
2021-11-22 07:54:08: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
Did you find any solution for my problem?
Hi Born,
According to the log, ActivePresenter could not get any video frames from the camera.
It seems to be a device-specific problem since it still works well in our tests.
Unfortunately, we could not find out the solution for this problem yet.
If possible, please upgrade to a higher version of macOS to see if it helps.
