Problem: This has been driving me crazy. In this set of questions I have a line that tracks statistics at the bottom of each slide. It works great until I get to the fill-in question. After that point it stops reporting the value of %attempted% correctly for that slide, and all subsequent slides. Moving the slide to a different position creates the same problem in that new position. Can you suggest why the variable %attempted% suddenly stops working on that slide?
ActivePresenter version: 8.5.8
OS: Windows 11
