After exporting a file to HTML5, is it possible for users to use a keyboard to navigate during the presentation/course? For example, arrow keys to go to next and preview slide, enter or spacebar to pause, etc.
ActivePresenter Pro Edition
8.3.0 - 64-bit build. (published: 2020.12.04)
OS: Windows 10
It’s possible to do that in ActivePresenter by using Key Strokes in Slide Master and adding events-actions to these Key Strokes.
Below are the steps for you to perform:
In the Properties pane > Interactivity tab:
– Set the correct value for the Key Stroke by pressing a key on the keyboard;
– Select Infinite for the Attempts option.
– Add event-action to the Key Stroke;
– Uncheck the Pause presentation to wait for user input and Report ID options.
Note: You need to use a True/False variable for the Space key, resize and set No Line for the Key Strokes to make them hidden.
For more information, please take a look at this sample: use keyboard to navigate_fixed.approj (428 KB)
