Hi, I’m a noobie here - I cannot seem to find a way to use keyboard events (other than any key down / up) - is there a way to use the right and left arrow keys to change scenes?
Javascript possibly?
John
John
Hi John,
You can get the key code from the event object e
by using JavaScript: e.domEvent.keyCode
Below is the entire script to change scenes when pressing the left / right arrow key (you can add it to the Key Down event of the document):
function onKeyDown(doc, e) {
var keyCode = e.domEvent.keyCode;
if (keyCode == 39) { // right arrow
doc.showNextScene();
} else if (keyCode == 37) { // left arrow
doc.showPreviousScene();
Hi Toan Le,
thank you for your very prompt reply. Thanks for this information I will give it a try later today - I am very excited about Saola and see some great possibilities for it. I look forward to the next version and what it may bring along for us
regards
John
