I’m not able find an option to turn off easing on transitions. Is that possible?
I’m not sure if you want to change to the linear easing or remove the transition.
If you want to change the easing, please select the animation segment, click Easing tool, and select another one.
If you want to remove the transition (i.e make the property jump to the value of the ending keyframe instantly at the ending keyframe time), please right-click the animation segment, and select Remove Transition from the menu.
Thank you, that works great. I have been using Edge Animate for a while, so I’m getting used to the different interface workflow. So far it’s been fairly easy to switch over to Saola’s workflow. Great program!
