Hi again,
i determined a strange behaviour of the toolbar in a HTML5 export (or HTML5 Preview) and i would like to avoid it, but i dont know how.
If I use (accidentaly) drag&drop to skip some slides inside the toolbar, the toolbar shifts outside the project boundaries. I think that using drag&drop is very common for many users, because you know this behaviour from youtube for example. A change of the Toolbar settings (Display Mode = AutoFit/Actual Size) does not make any difference. It is not linked with the browser, i tested Firefox as well as Edge.
Do you know how to fix this?
I can not upload any files here, so you can find a sample image at https://i.imgur.com/9hvnPMY.png
