My project timeline suddenly went to a scale where it’s divided by 0:00.5 increments - making the timeline very long and unwieldy to manage. I can’t find instructions to reset it, have tried resetting and restarting the software, have looked in the manual and on the web. I have no idea how it happened mid-project. I’m on a MAC, running ActivePresenter Pro Edition, Version 8.5.7
Hi Ellen,
To solve your concern, on the Timeline pane, you can click the Zoom Fit Timeline option.
Or, you can also try the hotkeys: option + command + “-”.
Best,
Quynh Anh
