Problem: I’m trying to create an event, where if one presses the button they are then moved to the next slide and the timeline of that slide starts. I have been able to do this with two other buttons on two other slides. This time though there are no timelines shown in properties, even though I have created the timeline.
At this time, ActivePresenter 8 allows adding events - actions for timeline at the current slide.
So, you can add variable to your project to achieve what you want.
