Rolf
#1
I want to run a timline in JS.
I use the following code:
var Soldier = this.name();
prez.startTimeline(Soldier, None);
But it does not work. I’m sure there is a simple mistake, but I cannot find it.
Thanks for your help.
Rolf
Please choose an appropriate sub-category to post your question or topic.
ToanLS
(Toan Le)
#2
Hi Rolf,
If you don’t need a callback for startTimeline
function, you can ignore it. None
is not declared anywhere so it could cause an error:
prez.startTimeline(Soldier);
Please also make sure that the object you attached this action and the timeline you want to start have the same name.
