I use ActivePresenter Free Edition.
The webcam is turned on and is displayed in the preview. During screen recording, the webcam image is not displayed. After stopping the recording, the camera image is shown in the final video. Did I miss a setting?
Please send the log of ActivePresenter via support@atomisystems.com so that we can analyze it further.
To view the log:
- In Start Page, click Preferences (the Gear icon)
- Select Miscellaneous.
- Click View Log.
For more detail, you can take a look at this quick video:
Hi Josef,
Thanks for sharing the log.
There is no founded issue from the log.
Kindly take note that after hitting the Record button, ActivePresenter will hide itself to record all actions on the screen.
You can click its icon in the Taskbar to show the Recording Toolbar.
After that, you can click Settings (the gear icon) and select Show Webcam in the pop-up dialog.
Please find out more useful information through this article: How to Start and Stop Recording in ActivePresenter 8
Best regards,
please my webcam is not working even when have saved the record. the told me the app couldnt access webcam, please help me restore the fault thanks
If you finish the recording and you’re informed that the webcam doesn’t work.
Unfortunately, there is no way to recover it.
To analyze your issue in detail, please send the log of ActivePresenter to support@atomisystems.com.
You can follow the guide as mentioned in the previous response.
Best regards,
