I was having trouble with my text entry objects in that the text entered was always too large for it to be legible because the text always ran outside the text entry. In this case, making the text smaller or making the object larger are not viable options; I was wondering if there was any way to wrap the text entered or even the placeholder text so that when the text is too long the remaining text appears on the next line. (Perhaps using javascript)
Honestly, any possible method for using multiple lines in text entry objects would be appreciated if any kind of text wrap is impossible.
Thank you
Text Entry objects don’t support multiple lines.
You should use Questions > Essay instead.
Thank you very much, this was very helpful.
I was also wondering if there were any known methods to allow for the any essay input to be entered immediately, as it is typed in.
Unfortunately, the current version of ActivePresenter doesn’t allow to submit the essay automatically when typing.
