Is it possible to insert a text table (e.g. columns and rows with data) into an AP slide?
Import from Powerpoint changes the table to an image, that becomes unreadable for screen readers.
Hi aga,
ActivePresenter doesn’t support inserting tables.
But we’ve just released version 8 that you can use a grid box to create a group of shapes similar to a table.
About importing tables from PowerPoint, we’ll try to support it in the future.
Hi Toan Le,
Thank you! We start testing the AP’8.
Regards.
