I’m testing the responsive layouts, and I’ve noticed that when I reduce the size of the text for the mobile viewport, it changes automatically to the rest of the viewports, making the text almost illegible in the Desktop mode.
Is there any way to customize the text size in every viewport independently?
I noticed that closed captioning does not have this feature. So when i turn on CC for mobile mode, it blocks out the entire screen. Is there a way around this?
I noticed that it works only once export. The cc size is the same when previewing on the activepresenter application.
However, i notice issue that the position of the cc is at the centre of the screen and still blocks out my content. How to move it to the bottom of the screen.
I have the same problem. The text appears super big taking the whole screen. I tried to insert the code, but still when exporting and seeing the video in the outside VLC program, the hard subtitles in the video are showing on the whole screen.
Have you updated to the latest version 8.3.2? You can find the Text Scale option in the Properties pane for Shapes and Closed Caption when editing responsive projects.
