Guten Tag,
ich würde gern wissen, wie ich eine Bildschirmaufnahme in mehrere Abschnitte teile und diese einzeln exportiere.
Danke im Voraus…
Guten Tag,
Danke im Voraus…
Hi Marcus,
If you want to split your video into many slides and then export each slide as video independently, take the following steps:
Kind regards,
Thanks for your answer. Now i have a new Problem
here is a screen
perhaps the tracks are too long ?
Please check your disk space again to make sure your computer has enough free disk space.
If the issue still persists, kindly send us the log file of ActivePresenter so we can take a look at it. (click ActivePresenter button > Preferences > Miscellaneous > View Log )
Feel free to attach the log here or send it to support@atomisystems.com
You can refer to this video to see the detailed steps:
BR,
