Table of contents / Collapsed
Can I create a table of contents on every slide – that is normally collapsed – and updates to indicate the progress as the course is being completed? My thoughts are that the sections of the course that are not yet complete would be “greyed” out.
ActivePresenter Version: 8
Mac OS Catalina 10.15.4
You can try grouping slides in Table of Contents. That helps you navigate through the each group (with box checked) not all the slides. To hide any slide, just deselect the check box next to it.
To do that, go to the Export tab > Player Settings > Table of Contents tab.
Please see the attached image for understanding better:
If you want to know more about controlling Table of Contents tab, check out this tutorial:
Yup this is it. Thanks!
