Problem: In a software simulation, when I press the TAB key, it is tabbing to the address bar instead of moving forward in the simulation. I have to press the tab key 3-5 times in order for it to return to the simulation and move forward. The tab key function is working properly on other screens.
ActivePresenter version: 8.4.0
OS: Windows 10
Hi Jared,
Can you send your project and its external data folder (named PROJECT_FILE_files) (if any) via support@atomisystems.com so we can take a look?
If these files are large, you can upload them to a cloud storage site like Google Drive then email us.
Best regards,
Hi Jared,
Thanks for sharing the file.
We took a look at it and respond to you via email.
Please check it out.
Best regards,
Thank you for the quick turnaround time.
