I’m going to feel really dumb if I just missed this somehow, but is there a preset way to shuffle the positions of objects at runtime other than the quiz choices?
Hi Roxie,
It seems that you want to shuffle the questions’ answer options.
If so, just select the answer area > Properties pane > Interactivity tab > Score & Reporting section > check the Shuffle Answers option.
Should this not address your concern, please describe your question in more detail with an illustrative image so we can assist you better.
Have a nice day,
No, I want to shuffle the location of other objects, such as two shapes. I know how to shuffle the answer choices.
Hi Roxie,
It would be really helpful if you can let us know the specific situation in that you want to shuffle objects.
Based on that, we can provide you with proper support.
It’s not specific, just a general question about preset actions. I guess for now, I’ll have to use javascript when I want it done.
Thank you.
Yes, Roxie.
Depending on specific cases we can provide you with corresponding scripts. So, feel free to let us know if you need further assistance.
