Svg import not displaying
Problem: I have created an svg diagram. It opens correctly using Edge, but when I import it into ActivePresenter stage, it does not display. A blank frame is evident only. What is the problem??
I tried to attach the svg to this post, but the file type is not authorized…
ActivePresenter version: 8.5.1
OS: Windows 64 bit
Could you please send the SVG file to support@atomisystems.com so we can check?
