Is there a way to export the entered text data of a survey in a TXT or CSV format
when the survey is finished? If possible not via Google.
Regards Marc
If you want to export the entered text data so that you can see learner’s answers, there are two ways to achieve it:
1, You can follow the instructions in this tutorial to send report data to an HTTP address:
2, You can write code server manually followed the instructions in ActivePresenter 8 User Manual (Page 283 - 290):
Yen
