Problem: On a second question attempt, the submit button disappears. How do I fix this ?
ActivePresenter version: 8.5.7
OS: macOS Montery
OS: macOS Montery
Each question has one attempt by default.
In order for learners to resubmit an incorrect answer, a question must have more than 1 attempt.
You can set the attempts for all questions (except for Likert questions) as many as you want.
Select the answer area > Properties pane > Interactivity tab > Score & Reporting section > Attempts.
For example, you can select Infinite if you want your students to answer a question until they do it right.
Please take a look at our tutorials > Editing > Interactive eLearning Topics about question types for more information on how to set attempts for them each.
If that’s not the case, please send us your project and its external data folder named in the PROJECT_FILE_files (if any) to support@atomisystems.com so that we can check.
If these files are large, you can upload them to a cloud storage site like Google Drive then send the download link to us.
Best regards,
Hang
