Hello,
I want to change style and position (top instead center) of the checkboxes in my multiple choice question.
Unfortunately I can only select the whole answer box (including text) to change colors, …
How can I only affect the checkbox?
Hello,
To style the checkbox of the multiple choice question, you select the answer area, then click the Format tab to choose one style from the Radio Style gallery. This allows you to change the color and size of the button.
Changing the position of checkbox is not supported in this version yet, unfortunately.
Best regards,
