Problem: when I export or preview the slides in H5 pages, the slides start autoplay continuesly, eventhough I insert buttons to stop it, it didn’t work
How can I stop the autoply function? I couldn’t find such option, or can anyone tells me how to view the slides by customed clicks?
Hi Emilia!
Maybe, the Auto Advance check box in the Properties pane is checked, so the slides start autoplay continuously.
If you inserted the button to stop presentation but it didn’t work, i think you previewed your presentation in Demonstration mode, you should select the 3 remaining modes.
Hi Li,
Thanks for the kind suggestion, but I have unchecked the Auto Advance box and previewed in test mode, still it didn’t work.
I am so confused.
Emilia
