Hi, do you know how to make the stopwatch start automatically only after the audio / video file has been completely played?
ActivePresenter Version: 8
OS:
OS:
Hi Leszek,
You need to insert an Animated Timer to create the stopwatch as follows:
In the main timeline, please place the Playhead at time when the video/ audio ends, then open the Insert tab, click Animated Timer.
You can refer to this tutorial to see how to work with Animated Timer: https://atomisystems.com/tutorials/ap7/working-with-animated-timer/
Yen
Thanks for the quick reply. Nice idea with this animation. I was able to solve this problem a bit differently. By means of the button. The audio / video cannot be paused, but the next ActivePresenter should be checked
Hi Leszek,
Thanks for getting back to me! I’m glad that you found the other way to solve the problem. We appreciate your feedback and try to improve it in the future.
