Part 2 of 2:
2020-08-09 08:46:47: flt sample format is not supported, s16 will be used
2020-08-09 08:46:47: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-08-09 08:46:47: Preparing to record audio from: Microphone (Rift Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 08:46:47: Failed to open audio stream to record. Error: Invalid number of channels.
2020-08-09 08:46:47: Preparing to record audio from: Microphone (Rift Audio). Channel: 1. Sample rate: 48000. Sample Format: 8
2020-08-09 08:47:12: Checking updates for ActivePresenter v8.1.1…
2020-08-09 08:49:09: Start capturing. Mode: Full motion. Method: 0. Capture Size: (1920, 1080)
2020-08-09 08:49:09: Video Codec: flashsv. Expecting FPS: 30.00
2020-08-09 08:49:09: Video will be recorded to: D:\Users\Janet Fried\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\video_20200809_08-49-09.mkv
2020-08-09 08:49:09: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-08-09 08:49:09: flt sample format is not supported, s16 will be used
2020-08-09 08:49:09: Audio will be recorded to: D:\Users\Janet Fried\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\audio_20200809_08-49-09.wav
2020-08-09 08:49:09: Preparing to record audio from: Microphone (Rift Audio). Channel: 1. Sample rate: 48000. Sample Format: 8
2020-08-09 08:49:09: Audio 2 will be recorded to: D:\Users\Janet Fried\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\audio_20200809_08-49-09_1.wav
2020-08-09 08:49:09: Preparing to record audio from: VG248 (NVIDIA High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 08:49:13: Waiting to start in 3410
2020-08-09 08:50:12: PrepareRibbonBar: 567ms
2020-08-09 08:50:11: Stop video recording. Frames recorded: 1735. Dropped: 0. Duration: 57804. Average FPS: 30.00
2020-08-09 08:50:11: Recorded video data size: 59804 KB
2020-08-09 08:50:11: AddVideo2Slide: Time spend: 27 ms
2020-08-09 08:50:11: ProcessRecordedAudio: duration (ms) 57839.854000
2020-08-09 08:50:11: ProcessRecordedAudio: duration (ms) 57844.854000
2020-08-09 08:50:14: RLMedia: No streams to mux were specified
2020-08-09 08:50:14: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-08-09 08:50:14: Audio Decoding Stats: Process 70.000000, Wait 0.000000
2020-08-09 08:50:14: Audio Encoding Stats: Process 21.000000, Wait 71.000000
2020-08-09 08:50:14: Audio Decoding Stats: Process 72.000000, Wait 1.000000
2020-08-09 08:50:14: Audio Encoding Stats: Process 26.000000, Wait 51.000000
2020-08-09 08:50:54: Render Project Size: 1920 x 1080
2020-08-09 08:50:54: Threads Used: 3 / 6, Memory Available: 6,418/16,329
2020-08-09 08:50:54: Preparing to play audio to: VG248 (NVIDIA High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 08:50:54: Audio frames decoding started.
2020-08-09 08:50:54: Video frames decoding started.
2020-08-09 08:50:58: 832a889c-9965-4631-abaa-9bf43ca8f6ec: Seek after: 34.000000
2020-08-09 08:51:35: ActivePresenter 8.1.1 (Release Build: 2020.07.24) shut down
2020-08-09 08:56:10: ActivePresenter 8.1.1 - 64-bit build. (Release Build: 2020.07.24) started
OS: Windows 10 (build 18362), 64-bit edition
CPU Count: 6
Hostname: DESKTOP-FNMPL60. Memory: 16,329 MB. Available: 8,873 MB. Memory Load: 45%
Disk Space: 953,864 MB (Free: 508,819 MB)
Project Location: D:\Users\Janet Fried\Documents\ActivePresenter
2020-08-09 08:56:10: TempDir: C:\Users\Janet Fried\AppData\Roaming\ActivePresenter\temp
2020-08-09 08:56:10: Direct3D rendering mode: hardware
2020-08-09 08:56:10: Direct3D device type: 1
2020-08-09 08:56:16: ---------------------LISTING WEBCAMS------------------------
2020-08-09 08:56:16: --------------------------------------------------------------
2020-08-09 08:56:16: flt sample format is not supported, s16 will be used
2020-08-09 08:56:16: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-08-09 08:56:16: Preparing to record audio from: Microphone (Rift Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 08:56:16: Failed to open audio stream to record. Error: Invalid number of channels.
2020-08-09 08:56:16: Preparing to record audio from: Microphone (Rift Audio). Channel: 1. Sample rate: 48000. Sample Format: 8
2020-08-09 08:57:24: Start capturing. Mode: Full motion. Method: 0. Capture Size: (1920, 1080)
2020-08-09 08:57:24: Video Codec: flashsv. Expecting FPS: 30.00
2020-08-09 08:57:24: Video will be recorded to: D:\Users\Janet Fried\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\video_20200809_08-57-24.mkv
2020-08-09 08:57:25: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-08-09 08:57:25: flt sample format is not supported, s16 will be used
2020-08-09 08:57:25: Audio will be recorded to: D:\Users\Janet Fried\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\audio_20200809_08-57-25.wav
2020-08-09 08:57:25: Preparing to record audio from: Microphone (Rift Audio). Channel: 1. Sample rate: 48000. Sample Format: 8
2020-08-09 08:57:25: Audio 2 will be recorded to: D:\Users\Janet Fried\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\audio_20200809_08-57-25_1.wav
2020-08-09 08:57:25: Preparing to record audio from: VG248 (NVIDIA High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 08:57:28: Waiting to start in 3407
2020-08-09 08:57:55: PrepareRibbonBar: 604ms
2020-08-09 08:57:53: Stop video recording. Frames recorded: 764. Dropped: 0. Duration: 25432. Average FPS: 30.00
2020-08-09 08:57:53: Recorded video data size: 12034 KB
2020-08-09 08:57:54: AddVideo2Slide: Time spend: 80 ms
2020-08-09 08:57:54: ProcessRecordedAudio: duration (ms) 25462.646000
2020-08-09 08:57:54: ProcessRecordedAudio: duration (ms) 25471.625000
2020-08-09 08:57:57: RLMedia: No streams to mux were specified
2020-08-09 08:57:57: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-08-09 08:57:57: Audio Decoding Stats: Process 21.000000, Wait 0.000000
2020-08-09 08:57:57: Audio Encoding Stats: Process 10.000000, Wait 25.000000
2020-08-09 08:57:57: Audio Decoding Stats: Process 28.000000, Wait 0.000000
2020-08-09 08:57:57: Audio Encoding Stats: Process 14.000000, Wait 22.000000
2020-08-09 08:58:05: Render Project Size: 1920 x 1080
2020-08-09 08:58:05: Threads Used: 3 / 6, Memory Available: 8,831/16,329
2020-08-09 08:58:05: Preparing to play audio to: VG248 (NVIDIA High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 08:58:05: Video frames decoding started.
2020-08-09 08:58:05: Audio frames decoding started.
2020-08-09 08:58:09: c5c4ceb6-eace-4807-8667-10afd323f363: Seek after: 19.000000
2020-08-09 09:00:13: ActivePresenter 8.1.1 (Release Build: 2020.07.24) shut down
2020-08-09 09:06:07: ActivePresenter 8.1.1 - 64-bit build. (Release Build: 2020.07.24) started
CPU Count: 6
Hostname: DESKTOP-FNMPL60. Memory: 16,329 MB. Available: 8,844 MB. Memory Load: 45%
2020-08-09 09:06:07: TempDir: C:\Users\Janet Fried\AppData\Roaming\ActivePresenter\temp
2020-08-09 09:06:07: Direct3D rendering mode: hardware
2020-08-09 09:06:07: Direct3D device type: 1
2020-08-09 09:06:11: ---------------------LISTING WEBCAMS------------------------
2020-08-09 09:06:11: --------------------------------------------------------------
2020-08-09 09:06:12: flt sample format is not supported, s16 will be used
2020-08-09 09:06:12: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-08-09 09:06:12: Preparing to record audio from: VG248 (NVIDIA High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 09:06:28: flt sample format is not supported, s16 will be used
2020-08-09 09:06:28: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-08-09 09:06:28: Preparing to record audio from: Microphone (Rift Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 09:06:28: Failed to open audio stream to record. Error: Invalid number of channels.
2020-08-09 09:06:28: Preparing to record audio from: Microphone (Rift Audio). Channel: 1. Sample rate: 48000. Sample Format: 8
2020-08-09 09:06:52: Start capturing. Mode: Full motion. Method: 0. Capture Size: (1920, 1080)
2020-08-09 09:06:52: Video Codec: flashsv. Expecting FPS: 30.00
2020-08-09 09:06:52: Video will be recorded to: D:\Users\Janet Fried\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\video_20200809_09-06-52.mkv
2020-08-09 09:06:52: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-08-09 09:06:52: flt sample format is not supported, s16 will be used
2020-08-09 09:06:52: Audio will be recorded to: D:\Users\Janet Fried\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\audio_20200809_09-06-52.wav
2020-08-09 09:06:52: Preparing to record audio from: Microphone (Rift Audio). Channel: 1. Sample rate: 48000. Sample Format: 8
2020-08-09 09:06:52: Audio 2 will be recorded to: D:\Users\Janet Fried\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\audio_20200809_09-06-52_1.wav
2020-08-09 09:06:52: Preparing to record audio from: VG248 (NVIDIA High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 09:06:55: Waiting to start in 3413
2020-08-09 09:07:03: PrepareRibbonBar: 382ms
2020-08-09 09:07:02: Stop video recording. Frames recorded: 211. Dropped: 0. Duration: 6984. Average FPS: 30.07
2020-08-09 09:07:02: Recorded video data size: 8241 KB
2020-08-09 09:07:02: AddVideo2Slide: Time spend: 46 ms
2020-08-09 09:07:02: ProcessRecordedAudio: duration (ms) 7016.896000
2020-08-09 09:07:02: ProcessRecordedAudio: duration (ms) 7021.896000
2020-08-09 09:07:05: Render Project Size: 1920 x 1080
2020-08-09 09:07:05: Threads Used: 3 / 6, Memory Available: 8,487/16,329
2020-08-09 09:07:05: Preparing to play audio to: VG248 (NVIDIA High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 09:07:05: RLMedia: No streams to mux were specified
2020-08-09 09:07:05: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-08-09 09:07:05: Audio Decoding Stats: Process 6.000000, Wait 2.000000
2020-08-09 09:07:05: Audio Encoding Stats: Process 6.000000, Wait 2.000000
2020-08-09 09:07:05: Audio Decoding Stats: Process 7.000000, Wait 2.000000
2020-08-09 09:07:05: Audio Encoding Stats: Process 8.000000, Wait 3.000000
2020-08-09 09:07:05: Video frames decoding started.
2020-08-09 09:07:05: Audio frames decoding started.
2020-08-09 09:07:36: Render Project Size: 1920 x 1080
2020-08-09 09:07:36: Threads Used: 3 / 6, Memory Available: 8,492/16,329
2020-08-09 09:07:36: Preparing to play audio to: VG248 (NVIDIA High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 09:07:36: Video frames decoding started.
2020-08-09 09:07:36: Audio frames decoding started.
2020-08-09 09:07:37: 93fedd58-cd91-4c98-9704-748eb32cbfcc: Seek after: 34.000000
2020-08-09 09:07:42: Render Project Size: 1920 x 1080
2020-08-09 09:07:42: Threads Used: 3 / 6, Memory Available: 8,479/16,329
2020-08-09 09:07:42: Preparing to play audio to: VG248 (NVIDIA High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 09:07:42: Video frames decoding started.
2020-08-09 09:07:42: Audio frames decoding started.
2020-08-09 09:07:46: 93fedd58-cd91-4c98-9704-748eb32cbfcc: Seek after: 33.000000
2020-08-09 09:08:00: Render Project Size: 1920 x 1080
2020-08-09 09:08:00: Threads Used: 3 / 6, Memory Available: 8,442/16,329
2020-08-09 09:08:00: Preparing to play audio to: VG248 (NVIDIA High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 09:08:00: Audio frames decoding started.
2020-08-09 09:08:00: Video frames decoding started.
2020-08-09 09:08:04: 93fedd58-cd91-4c98-9704-748eb32cbfcc: Seek after: 33.000000
2020-08-09 09:08:22: Render Project Size: 1920 x 1080
2020-08-09 09:08:22: Threads Used: 3 / 6, Memory Available: 8,492/16,329
2020-08-09 09:08:22: Preparing to play audio to: VG248 (NVIDIA High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 09:08:22: Video frames decoding started.
2020-08-09 09:08:22: Audio frames decoding started.
2020-08-09 09:08:26: 93fedd58-cd91-4c98-9704-748eb32cbfcc: Seek after: 18.000000
2020-08-09 09:08:49: Render Project Size: 1920 x 1080
2020-08-09 09:08:49: Threads Used: 3 / 6, Memory Available: 8,460/16,329
2020-08-09 09:08:49: Preparing to play audio to: VG248 (NVIDIA High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 09:08:49: Audio frames decoding started.
2020-08-09 09:08:49: Video frames decoding started.
2020-08-09 09:09:11: Render Project Size: 1920 x 1080
2020-08-09 09:09:11: Threads Used: 3 / 6, Memory Available: 8,482/16,329
2020-08-09 09:09:11: Preparing to play audio to: VG248 (NVIDIA High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 09:09:11: Audio frames decoding started.
2020-08-09 09:09:11: Video frames decoding started.
2020-08-09 09:09:21: Render Project Size: 1920 x 1080
2020-08-09 09:09:21: Threads Used: 3 / 6, Memory Available: 8,475/16,329
2020-08-09 09:09:21: Preparing to play audio to: VG248 (NVIDIA High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 09:09:21: Video frames decoding started.
2020-08-09 09:09:21: Audio frames decoding started.
2020-08-09 09:09:22: 93fedd58-cd91-4c98-9704-748eb32cbfcc: Seek after: 16.000000
2020-08-09 09:09:36: Render Project Size: 1920 x 1080
2020-08-09 09:09:36: Threads Used: 3 / 6, Memory Available: 9,082/16,329
2020-08-09 09:09:36: Preparing to play audio to: VG248 (NVIDIA High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 09:09:36: Audio frames decoding started.
2020-08-09 09:09:36: Video frames decoding started.
2020-08-09 09:09:40: 93fedd58-cd91-4c98-9704-748eb32cbfcc: Seek after: 33.000000
2020-08-09 09:10:11: ActivePresenter 8.1.1 (Release Build: 2020.07.24) shut down
2020-08-09 09:32:34: ActivePresenter 8.1.1 - 64-bit build. (Release Build: 2020.07.24) started
CPU Count: 6
Hostname: DESKTOP-FNMPL60. Memory: 16,329 MB. Available: 9,127 MB. Memory Load: 44%
Disk Space: 953,864 MB (Free: 508,808 MB)
2020-08-09 09:32:34: TempDir: C:\Users\Janet Fried\AppData\Roaming\ActivePresenter\temp
2020-08-09 09:32:34: Direct3D rendering mode: hardware
2020-08-09 09:32:34: Direct3D device type: 1
2020-08-09 09:32:38: ---------------------LISTING WEBCAMS------------------------
2020-08-09 09:32:38: --------------------------------------------------------------
2020-08-09 09:32:38: flt sample format is not supported, s16 will be used
2020-08-09 09:32:38: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-08-09 09:32:38: Preparing to record audio from: Microphone (Rift Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 09:32:38: Failed to open audio stream to record. Error: Invalid number of channels.
2020-08-09 09:32:38: Preparing to record audio from: Microphone (Rift Audio). Channel: 1. Sample rate: 48000. Sample Format: 8
2020-08-09 09:32:39: flt sample format is not supported, s16 will be used
2020-08-09 09:32:39: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-08-09 09:32:39: Preparing to record audio from: Microphone (Rift Audio). Channel: 1. Sample rate: 48000. Sample Format: 8
2020-08-09 09:32:41: Start capturing. Mode: Full motion. Method: 0. Capture Size: (1920, 1080)
2020-08-09 09:32:41: Video Codec: flashsv. Expecting FPS: 30.00
2020-08-09 09:32:41: Video will be recorded to: D:\Users\Janet Fried\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\video_20200809_09-32-41.mkv
2020-08-09 09:32:41: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-08-09 09:32:41: flt sample format is not supported, s16 will be used
2020-08-09 09:32:41: Audio will be recorded to: D:\Users\Janet Fried\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\audio_20200809_09-32-41.wav
2020-08-09 09:32:41: Preparing to record audio from: Microphone (Rift Audio). Channel: 1. Sample rate: 48000. Sample Format: 8
2020-08-09 09:32:41: Audio 2 will be recorded to: D:\Users\Janet Fried\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled_tempdir\audio_20200809_09-32-41_1.wav
2020-08-09 09:32:41: Preparing to record audio from: VG248 (NVIDIA High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 09:32:44: Waiting to start in 3404
2020-08-09 09:50:57: ActivePresenter 8.1.1 - 64-bit build. (Release Build: 2020.07.24) started
CPU Count: 6
Hostname: DESKTOP-FNMPL60. Memory: 16,329 MB. Available: 8,998 MB. Memory Load: 44%
Disk Space: 953,864 MB (Free: 504,394 MB)
2020-08-09 09:50:57: TempDir: C:\Users\Janet Fried\AppData\Roaming\ActivePresenter\temp
2020-08-09 09:50:57: Direct3D rendering mode: hardware
2020-08-09 09:50:57: Direct3D device type: 1
2020-08-09 09:51:03: ---------------------LISTING WEBCAMS------------------------
2020-08-09 09:51:03: --------------------------------------------------------------
2020-08-09 09:51:03: flt sample format is not supported, s16 will be used
2020-08-09 09:51:03: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-08-09 09:51:03: Preparing to record audio from: Microphone (Rift Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-08-09 09:51:03: Failed to open audio stream to record. Error: Invalid number of channels.
2020-08-09 09:51:03: Preparing to record audio from: Microphone (Rift Audio). Channel: 1. Sample rate: 48000. Sample Format: 8
