I have to record a software simulation in which we have to see the mouse cursor and the clicks I do. At the same time I speak to explain what I do on the sceen. Whenever I click on something, it mutes the sound of the microphone and interrupts my explanation. I tried several configurations but I can not find a solution for this problem. Could you help me?
ActivePresenter Version: ActivePresenter Free Version 7.5.6
This is not a reply. It is more info about the trouble we are experiencing.
We run ActivePresenter version 7.5.6.
We tried the option record video but the pointer is still invisible.
This problem doesn’t exist with version 6.1.x.
Moreover, the TIMELINE doesn’t allow us to click on the Split Slide icon.
We run the Free version.
Any ideas?
Thanks
Maria
You should use “Record Video” for these kind of tutorials.
“Record Software Simulation” should only be used when creating slide-based tutorials.
In this mode, ActivePresenter will create a seperate slide every time you click or press keyboard and so your voice will also be splitted into slides which results in the issue you’re having.
Or you should pause your voice before each mouse click.
