Problem: Is there a way in Javascript to get the name of the current slide similar to ‘currentSlideIndex()’?
Thanks,
ROlf
ActivePresenter Version: 8
OS: win10
Thanks,
ROlf
OS: win10
Hi Rolf,
In the current version, slide name has HTML format, it’s not plain text as object name.
So it should be used only for showing (not storing, comparing … in JavaScript), and you can use apCurrentSlideLabel
variable for this purpose.
Thanks, Toan,
so just to be clear. I cannot have a JS code in the master where I do something like
if(apCurrentSlideLabel == ‘Hello’) {…}
Best, Rolf
Yes, you should not use JS code like that.
prez.variable('apCurrentSlideLabel')
will return something like "<p style=\"margin-top: 0px; margin-bottom: 0px; \">Hello</p>
You can assign a name for a slide in its On Load event and check this name in other events. For example:
// in a slide On Load
prez.myCurrentSlideName = 'Hello';
// in that slide On UnLoad: reset current slide name
delete prez.myCurrentSlideName;
// in another event
if (prez.myCurrentSlideName == 'Hello') {...}
Thanks, Toan, that’s really helpful.
Best,
Rolf
