Hello,
I am trying to make a responsive project that can be used on multiple devices.
I am using the slide master to adjust the textscale for various screen sizes. For title and textboxes this works fine in my project. When I close the master view things change.
But I have also made a layout for a question (with a placeholder for a question). I have adjusted the textsizes to my wishes.
But when I close the master view there is no update of my existing question slides.
When I select the slides that I want to change and press layout… nothing happens
The problem is in the questions themself. I use MCQ a lot. The text properties of the answer options are not changed.
When I add a NEW slide the layout is correct…
Am I doing something wrong?
best regards
