If i put a text box question into a slide master, such that this text box is visible on all slides with this layout.
Will this over-write the same variable, or does slide master create a text box variable for every slide the master layout applies too?
ActivePresenter will create text box for every slide in the output.
However, you can assign a variable to a text box that many text box can update value to a variable.
