Hello,
my quiz has a slide index at the top of each question slide.
Slide 1 is just a picture. The first question is on slide 2.
Therefore I want the slide index on slide 2 to show “1/13 questions” instead of “2/13 questions”.
How can I do that?
The code is: %apCurrentSlideIndex%/13 questions
Hi Mike,
To achieve your goal, you should create a variable at first.
Then, on the slide On Load event, set actions to that variable equal to apCurrentSlideIndex -1.
For more detail, please take a look at the attached sample:
Sample Slide Index.approj (804 KB)
Best regards,
Thanks a lot for your example.
It works now.
