Hello,
Is it possible, when reviewing a quiz, to skip the first slides ? And start from the slide number 4 for example ?
Hello,
Hi Benjamin,
Yes, you can add the following action to On Load event of the first slides to skip them:
Nice ! Works perfectly !
Thanks a lot !
