Is it possible, when reviewing a quiz, to jump to ONLY the incorrect questions and skip the ones that the user got right?
Unfortunately, ActivePresenter doesn’t support this feature yet. We will support this feature in future releases.
In addition, you can use variables and action condition as a workaround. The idea is we will use each variable to keep each slide result. Then in previewing mode, we will check to show review feedback if the slide result is false.
You can see the sample project in the attachment.
review_incorrect.approj (436 KB)
